FTA View Plane Orientation
Ok, here is the deal. When i go and create a front view for FTA it aligns the axis of the view plane with the global axis system, but I am working on a local axis and would like to have the axis of the view aligned with the local instead of the global. Is there anyway to do this? I am asking because I need the annotation aligned with the part, and when you are creating the linear dimension they are aligned to the global axis. I know alot of adjustmenst can be made to line them up right, but I was wondering if there was a faster way.
RE: FTA View Plane Orientation
This will orient the FTA View plane in the XY plane, and most text will written in the X-direction.
If that's not the orientation you want, just make a new axis system and use it to define your FTA View plane
