critical flow
critical flow
This may sound stupid but i am looking for a true definition of critical flow.
In the application of production testing or frac flowback I am under the impression that critical flow is defined as the point at with gas and fluid can be brought back without causing casing or formation damage is this true.
RE: critical flow
Hope this helps.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
The harder I work, the luckier I seem
RE: critical flow
