voltage output
voltage output
voltage output
What are the relative advantages and disadvantages of having a voltage output as against a current output?
RE: voltage output
Of what?  Do you mean a constant-voltage power supply versus a constant-current one?
Don
Kansas City
RE: voltage output
w.r.t. controls?
Current signal is less susceptible to interference.
RE: voltage output
thanks Dan.
That was realy helpful!!
RE: voltage output
Perhaps at least as important as eliminating voltage drops as a problem, many 4-20 ma sensors are powered by the current below 4 ma.  This means that only two wires are required for power and the signal.
