DAF for Oil and CO2 Removal
I have a waste stream that requires oil separation followed by CO2 and O2 removal.  I started by looking at individual processes for each but a search of this board and it appears I may be able to combine oil and CO2 removal using a DAF unit installed within a oil separater.  Venders seem willing to accomodate but wonder how well it would work?
I would then scavage the O2 by chemical dosing.
The second question is has anyone removed waste oil under pressure?  Or rather without breaking the line pressure as happens with a atmospheric oil tank seperator.  I was thinking maybe cyclones or some sort of centrifugal system.
RE: DAF for Oil and CO2 Removal
DAF's are ususally operated at atmospheric pressure so O2 and CO2 would not require special removal.
The DAF usually has a recycle where air is added under pressure to supply the motive separation force.
Any pressurized tank with some typd of baffle may be used as an oil/water separator. The product water is taken off the bottom and the oil is decanted off the top. Separation tanks are common in the chemical industry.
