Rectangular springs
Rectangular springs
Since a helix/spiral sweep requires the use of a circle, how does one create a spring that is rectangular in shape- i.e. a rectangle with tangent arcs on the short ends? I am a new to this (undergrad) and I do not know enough about 3d sketches to make a smooth angled curve.
RE: Rectangular springs
h
Chris
SolidWorks 08 0.0/PDMWorks 08
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
Check out the methods of the first and last tutorials here:
htt
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
but if you need your path to be in broken line (broken line sprial), you have to use 3D Sketch (very complicated in this case), create any profile and then use sweep feature as usual
Chris
AutoCAD 06
ctopher's blog
Jeff Mowry
Jeff Mowry
