anoxic zone baffle wall
I am designing a baffle wall inside a concrete aeration tank. The baffle is to create a separate anoxic zone for the denitrification. Any suggestions regarding the material, construction and type of flow (over or under the wall)would be appreciated. Thank you
RE: anoxic zone baffle wall
I have also looked a grp panels supported on stainless steel. This cost less, but required a lot of bracing off the walls to be stable. If you went with this underflow is realy the only option and isolation is not possible.
