Phillips head torque effects
I am trying to write a new assembly torque specification for our product, but I'm running into a quandry that Google is not helping me solve. This is not a high-stress structure, but it is a primarily sheet-metal product that needs to do a sufficient job of holding itself together through shipping and daily use. We've had problems with fasteners loosening and falling out due to insufficient installation torques, so we're writing our assembly facility a spec.
The problem is that we are currently (I'm trying to change this) specifying a lot of phillips head button screws. I can find plenty of specs for torquing cap screws and hex screws of these sizes, but I think that a cheap, standard phillips head screw must change the failure mode. It seems to me that the phillips contour will strip out long before a standard hex head preload torque is reached.
a) Is that a correct presumption?
b) If it is, then does anyone have a guide or an idea of what the reduction is to transition from a standard torque spec to a phillips head torque spec?
These are all steel-on-steel fastener interfaces.
Thank you,
~Vay
Thank you,
~Vay
RE: Phillips head torque effects
Are you talking screws into nuts (or 1-1.5D threaded holes) or sheet metal screws?
We've had similar problems but the fact that we have screws into so many different 'threads' (sheet metal, nuts, studs, aluminium, stainless ...) as well as a range of heads means that I'm very concerned about using standard 'rule of thumb'.
The manufacturing engineering manager came over all excited the other day because he'd got a sheet from a vendor with the torques they use, but it didnt' take account of all these variables as far as I could see.
I'll be interested to learn more too.
KENAT, probably the least qualified checker you'll ever meet...
Ah, good point. We've got a mix, mostly screws into PEM nuts and regular nuts, but some applications involve screws into sheet metal and other materials (plastics, PCB mounts). We're planning a spec value for screws into PEM nuts and regular nuts and a lower spec for screws into plastic and sheet metal.
Thus far, our in-house measurements are starting to suggest that there doesn't need to be a distinction between Phillips head installation torque and other hex heads. The Phillips heads just have a tendency to fail after a few installation / removal cycles, far sooner than hexes of any sort.
~Vay
I do know there are some here who don't like small button heads (hex) as they think the hex gets rounded out too often and it can cause problems.
http://www.acument.com
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
No.
There is no such thing as a "standard torque" (although too many people believe that there is). Mainly because torque is not the desired goal with a threaded fastener. A known tension (preload) is the goal. There is a tenuous relationship between torque and preload, so measurement of torque is often used to estimate the achieved preload in an assembly environment.
The nature of the torque - tension relationship for any particular application is not in any way a function of the drive feature of the fastener.
However, if the drive feature fails before the desired preload is achieved, then the joint will fail in service.
Bottom line: If you need your screws tighter, don't use phillips.
- In production, it can be used with auto- feed drivers because it's forgiving of slight misalignment.
- In a less than pristine application environment, e.g. on a dirtbike, it speeds service because you don't have to clean every last little bit of dirt out of the recess in order to engage the driver for disassembly and reassembly.
Ultimate drive torque is not one of its advantages.
Mike Halloran
Pembroke Pines, FL, USA
If you need your assembly to use higher torque, I think your first step should be to go to a Robertson or Torx head.
The idea that a cross recess is better than other drive styles with respect to off-axis driving is completely untrue. A nice comparison was made recently by Archetype Joint and shows the maximum angle for a cross recess is 2°, while a Torx can be driven at 14°, and a hex can be started at 17° but finishes at 11°. The study is available for free here:
http
You have to sign for a free membership to view the document.
Cory
If there are no requirements that you have to use Phillips head screws, why not got to socket caps? Socket caps are my first choice. You can check out Mcmaster.com for a variety of socket caps.
Tobalcane
"If you avoid failure, you also avoid success."
As a little aside to this discussion, many of you have pointed out the weaknesses of Phillips head fasteners when it comes to re-usability and installation control. I couldn't agree more, and I have already gotten approval to replace our Phillips fasteners with socket head and hex head versions. I will be working with my fellow designers and production facilities to phase out cross-head fasteners in favor of hex or torx-based interfaces.
Thanks for the assistance,
~Vay
A guy at my last place used to jokingly specify '2 white nuckles' now I just need to know that in standard units.
Vayene, just a thought I had for your application, can you use threadlocker (or maybe patched screws) at all? If you're using the pre-load to mainly stop it from un doing rather than any other reason would this work?
On my first pass, I do not care what kind of socket my screw has. I calculate screw torques based on 90% of proof stress or yield stress. I have done this for Phillips screws, and had no problems torquing them down. As far as I know, I have had no problems with them torquing out either.
JHG
