How trigger the expression information from post
Hi
How to take the output of expression information from post
For example dia 10.0
how to extract the information through postprocessor
i tried with the inbuilt variable....its not triggering information
RE: How trigger the expression information from post
You can use the MOM command:
[MOM_ask_ess_exp_value "expression name here"]
An example : variable name is "x_len" and expression name is "blkx"
catch {if {[MOM_ask_ess_exp_value blkx] != ""} {
set x_len [MOM_ask_ess_exp_value blkx]}}
MOM_output_literal "(Blank Length is : $x_len)"
John Joyce
Tata Technologies iKS
1675 Larimer St.
Denver, CO
www.myigetit.com
Thank you verymuch...
Its working !!!!
