mesuring distance on a composite curve
hi everyone,
could anyone solve my case:
I need to divide and mesure distance on composite curves, for example, a line followed by an arc followed by another line.
I use solidworks 2008.
please, help, I really can't find how to do it.
nico
nico
RE: mesuring distance on a composite curve
Are all the lines and arcs to be the same length?
thx for taking time.
Here are two sample of what I need to do. One of them is the middle curve of a stair.
Highlight the composite curve in the tree and hit the measure tool ....
Remember...![[idea] idea](https://www.tipmaster.com/images/idea.gif)
"If you don't use your head,
your going to have to use your feet."
If the equality does not need to be precise, a simpler version of CorBlimeyLimey’s suggestion would be to use line segments constrained to be on the curves and have equal length, (think approximating a circle with a polygon). The make path sketch tool may help by allowing the line end points to cross between the arcs.
Eric
