Bluetooth mouse compatibiity Dell laptop
I have 2005 running on a Dell laptop with a Dell bluetooth mouse I use for traveling (Vista OS). I have not been able to use the 'wheel-depressed' pan function. I think I need to delete the Dell driver and let Microsoft control the mouse. The dell driver may be overriding the ACad settings. I am unsure how to do this w/o screwing up a bunch of stuff I have no business messing with. Can somebody walk me through this w/o alot of effort. Should I try to save the dell driver for future ref or is this a waste of time? Thanks for your help.
RE: Bluetooth mouse compatibiity Dell laptop
I hope you found a solution by now, but if not I have one for you!
Under the Blue Tooth Software (Dell Set Point)...
Button 3 should be set to "other", then in Select Function, choose Middle Button.
It is NOT a Microsoft problem. Dell just has their software configured different. Reset that button to a Middle Button and you will be good to go.
Good luck!
