How I display the reaction per floor in ETABS
Hello
i do my best to display the reaction per floor in etabs programm put i can not
only reaction i can display at base level only
anyone have idea about that question
best regards
best regards
RE: How I display the reaction per floor in ETABS
i need to check the column load per floor because i have building 35 story and the size of columns should be decrease from floor to floor.
for example
the columns at the basementis 1500mmx500mm,
at the second floor it should be less than that
but how i display the column load per floor in etabs i do not know
thanks
thanks
you will see the table show you column foce per floor with all case of loading
best regards
