centerline VS line
centerline VS line
centerline VS line
Hello-
I am interested in what is the difference between a "line", a "centerline in Solidworks.
It seems like a line set up as construction geometry could be used as a centerline.
When do you decide to use one or the other?  Thanks for any tips.
-Jason
RE: centerline VS line
I prefer construction lines, as they can be used to find slot centers and other bits of symmetry that centerlne entities do not.  Also, centerlines can be re-associated if the model changes.
