How much do you keep in the way of calcs
I recently got to run my own project for the first time. It was a very small project, but I was the one coordinating with the architect and doing all of the detailing/design.
This is a question for the experienced engineers out there. How much of the calculations that changed during design do you keep for the project?
Just as an example, I designed some clips to support a 17' strip window 6" from face of wall. Initially these clips were carbon steel (Fy=36 ksi) with a width of 3" (for architectural considerations) and I designed the thickness to be 1/4".
Then the architect changed it from carbon steel to stainless steel (Fy=30 ksi) and it needed to be 4" wide with 1/4" thickness.
Then I talked to the glass guy to get an idea of how much bearing width they want to see (turned out to be a minimum of 4") and found out that they don't like to use SS greater than 3/16" so they can maintain a tight radius on the bends (It was a bent plate).
The final product ended up being a 3/16" thick x 5" wide bent plate. After all of that, I have three different designs for this one simple bent plate.
I am sure others have been down this road with similarly small things (and I am sure with larger things).
The question is whehter there is any reason for me to keep the first 2 designs for the bent plate with my organized project calculations or if they can just be tossed out.
Any insight here would be greatly appreciated.
RE: How much do you keep in the way of calcs
As stated above, a detailed calc package can be used against you in some cases, so just keep that in mind. Especially if you did any quick and dirty approximations.
Long story short, I keep everything, mostly to provide a recollection on how the design evolved and in case anyone ever asks me to justify my hours.
strucguy
The lawyer indicated the first thing a law firm would do if they filed suit on one of his jobs, would be to hire another engineer to go over all the calculations. The laywer's advice was not to give them information that they could use in a law suit.
To this piece of advice, if all the calculations follow code or are correct and nothing has been missed what is the point? It only helps to clear one's name.
Without this, it just muddies the waters and there is potential that the engineer in question will inherit unassumed liability, ie hidden construction errors, etc.
VOD
The reasoning was that despite our best efforts and quality control measures, the calculations are never perfect. Even if there are no glaring errors, there are always minor inconsistencies that can and will be used against you by lawyers. Judges and juries do not have the technical expertise to determine if an error is a major problem and the lawyer will try to convince them it is. It may cause just enough doubt in their minds to decide against you.
It is a much harder task for the lawyer to prove that a structure is deficient than just to show that there were arithmetic or typographic errors in the calculations. The calcs can always be redone to show that the design does meet the legal standard of care.
But if you are going to destroy the calcs, make sure that you consistently destroy calcs for all projects. If you don't, the lawyers will argue that you destroyed the calcs for the specific project in question because you were trying to hide something.
In Canada, at least in the province of Alberta, the Association's guidelines for professional practice mentions some form of completeness of the calculations.
APEGGA January 2006
Guideline for Professional Practice
"Accurate and complete records should be kept for all projects until the professional liability period expires. These records would include documentation of the methodology
used in performing professional work, drawings, design calculations, shop drawings,reports and other communication documents."
Again the application of law and the rights of individuals in this regard may be entirely different between the two countries.
For firms that do large volumes of work, it seems like it is not a question of IF you will be sued but WHEN. The problem is not unique to engineering either. Some state governments are being forced to enact medical malpractice liability reforms because doctors refuse to work there. The insurance premiums are so high to cover potential lawsuits that they cannot stay in business.
This is the same reason that the insurance group DPIC originally started their Structural Engineering Risk Management Council (SERMC). The ACEC RMP was started a few years ago when SERMC was discontinued.
I have been fortunate enough to never have been sued (yet) in my career. But I have been involved as a consultant in a couple cases that went to litigation. Those experiences were enough to convince me that the U.S., structural engineers should take every CYA measure possible.
Thanks for clarifying this issue.
One thing however crops up since the Minnesota bridge collapse. The DOT has instructed consultants and contractors to preserve all documents and data relating to the bridge. This can be found on their website and has been published in Roads and Bridges magazine.
I guess such instruction holds no real legal weight, and depends entirely on the goodwill of the naive.
VOD
Keep everything but void out unused calc’s. It is cheaper to store then it is to recalculate or redraw. The best investment you can make is to scan and archive everything, we hired 6 summer interns rented 3 photo copiers with scanners and 2 plotters with scanners, a couple of summers ago. Three months later, every job we have done, even the hand drafted jobs are just a click away. Drawings, calculations, specs, reports, everything. Now instead of waiting for staff to pull files we can open and print files in seconds.
It has been a great help to our young engineer’s to research different methods of construction. And quickly find an existing detail that works instead of reinventing the wheel.
