AB CompactLogix Memory Estimate
I'm investigating using the subject PLC to control a wastewater treatment process. I'm planning on 20 digital I/O and 16 analog I/O and I'm trying to estimate the memory needed. The AB selection guide gives a memory of 4000 bytes needed per controller task, but I'm not clear on what constitutes a "task". Is each "rung" a task, or is each "instruction" a task?
RE: AB CompactLogix Memory Estimate
I suspect you will see somewhere a list of "tasks".  A task is probably something like a PID algorithm.  OR a data base function.   Some canned function.   A whole lot of PLCs don't even have that much memory total but support thousands of rungs so it can't be just a rung.
Keith Cress
