Compressive Stresses
If I had a graph that showed a blade had compressive stresses ranging from 100 ksi to 0 from the surface (depth = 0) to .006 below the surface, would I be able to simulate that in a model and see what affect that has on a part's frequency? Can this be done using Workbench or does it need to be done in Classic If it can be done at all?
RE: Compressive Stresses
Yes, there are a few different ways you could do it.  I'd recommend looking at the PSTRESS command.  You'll have to run a static analysis first.  The stiffness matrix will then be updated for your modal analysis to include stress stiffening effects.
