File past its end
File past its end
File past its end
I'm currently use solidworks 2007 and i'm getting this error when trying open to an assebly file "An attempt was made to access an unnamed file past its end". Has anyone seen this error before.
RE: File past its end
The preview data for the configuration is most likely corrupt. Open the file and perform a Save As. This should fix the error message. Go through each configuration and Save. This will restore the preview data.
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
