Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I'm so glad I found this site... Now I can get some sleep, because my problem is solved..."
Geography
dgkhan (Structural)
7 Dec 07 7:40
Using Enercalc for Pole embedded in soil, gives restraining force if pole is restained with cocnrete floor etc. How to manually cross check this force?
jdonville (Geotechnical)
7 Dec 07 10:43
dgkhan,
Would diameter of pole x Area of contact w/ concrete x design compressive strength of concrete do it?
d x A x f'c
You may need to use a reduction factor for f'c (typically 0.85) and/or an arching effect multipiler for d (typically 2-3).
Hope this helps.
Jeff
msquared48 (Structural)
7 Dec 07 13:54
Force at the concrete level should be the sum of your lateral P force at the top of the pole plus your passive pressure against the pole and footing under the slab level.
Remember, for a pole barn, 2X the IBC table values of passive pressure are allowed since more deflection is permissable.
Mike McCann
McCann Engineering
Close Box
Join Eng-Tips® Today!
Join Us             Close
