Error when Launching NX4
I have installed NX4 on a laptop (windows XP) to do a demo.
I have installed the Flexlm license manager and that runs ok.
However, when I launch NX, I get the following error:-
Microsoft Visual C++ Runtime Library.
   Runtime Error!
   Programme C:\Programe Files\UGS\NX 4.0\UGII\ugraf.exe
   Abnormal Programme Termination
I've tried reinstalling NX & the flexlm.
Any Ideas.
Cheers in advance.
RE: Error when Launching NX4
I'm not promising this is the problem, but if you have Internet Explorer 7 installed, you need to delete %UGII_BASE_DIR%/ugii/psapi.dll.  See the SFB below from Siemens' website:
[start clip]
SOFTWARE FIELD BULLETIN
NX 4 and NX 3 Will Not Start After Internet Explorer V7.0 Is Installed
Symptom/Problem
Attempting to start NX 4 or NX 3, once IE V7.0 is installed, will display an error:
Fatal Error
Fatal error detected unable to continue
The syslog file will have the entry:
     Daylight Time
     +++ Unhandled operating system exception: e06d7363
     [1] 7C812A5B
     (kernel32)
     [2] 202B908A
     (libsyss)
     [3] (libsyss)
     [4] 202B7AD8
Solution/Workaround
Delete the %UGII_BASE_DIR%/ugii/psapi.dll file.
Note: UGS provided the psapi.dll file for Windows NT compatibility. However, it is no longer needed since it is included in the Windows 2000 and Windows XP operating systems.
References/Notes
If any questions arise regarding this field bulletin, the Global Technical Access Center may be contacted at (800) 955-0000 for USA & Canada. If you are outside the United States and Canada, any questions regarding this or any other SFB should be directed to your local support office, quoting the SFB number.
[end clip]
If that doesn't work or you have already done that, and still get the error, I would call GTAC unless someone else knows for sure what the problem is.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
