VFD Feedding a Power transformer
Dear All ,
We are developping a motor control test center project, and some of our collegues are suggesting to use a VFD to fed a power transformer in order to change the transformer´s voltage output  with out change the frecuency, this is intendded for load and  no load test.
Any one with similar experience ? pros and conts??
Thanks for the Inputs
Petronila
RE: VFD Feedding a Power transformer
Hey Petronila.
As I remember, Gunnar recommend you several things in the Electric motors forum.
Why you ask again???
Regards.
Slava
Yes Slavag,
But the electric Motor forum is for motors and I would like to know more about the possible problems with the transformer.
Petronila
Wouldn't the VFD change the frequency not the voltage?
VFD does both, with limitations.
Thanks Edison,
Culd you sayd me you`r shop name?
Petronila
petronila
Please visit www.edison.co.in.
* I would go green if only I were not yellow *
I would not trust test results from a VFD supply unless signifiicant filtering was used to almost eliminate harmonics.  One of the purposes of the load and no load tests on a transformer is to measure the losses and impedances accurately.  Harmonics from the VFD's may increase losses in the transformer and can make it difficult to get an accurate KW reading.
