Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I also believe that we all can contribute to each other's growth by sharing knowlege and experiences. I would love to take my skills and help people around the world solve problems..."
Geography
Corrosion prevention for pumping brackish ground waterHelpful Member!(2)
GTOJim (Mechanical)
6 Dec 07 17:00
Hi All, I work in the pump rental industry, and I am designing a new pump that will be used for pumping ground water out of a construction site. This particular pump will be used in coastal areas (i.e. Florida) where the gound water could be brackish. The pumps we are using now have carbon steel components, and we are obviously having corrosion problems with these parts. What types of materials would be best to use that would be both cost effective and be resistant to cloride corrosion cracking and other seawater based corrosion? Water temperature would be ambient, 50-70F.
GTOJim
Helpful Member!  SJones (Petroleum)
7 Dec 07 0:14
In the Eng-Tips search above use the terms +pumps +seawater +materials - there are over 300 hits discussing seawater pumping
Steve Jones
http://www.pdo.co.om/pdoweb/
SJones (Petroleum)
7 Dec 07 0:21
Helpful Member!  EdStainless (Materials)
7 Dec 07 13:41
There is a small booklet available from NIDI that talks about pumps for brackish ans saline waters.  Great stuff.
Plymouth Tube
strider6 (Materials)
3 Jan 08 13:46
i think that in your conditions, brackish water at ambient temperature, a Stainless Steel can do the job, but there are many factors to be considered for the final selection; type of pump, range of chlorides concentrations...
http://www.stainless-steel-world.net/pdf/11003.pdf
Guidelines For the Use of Copper Alloys In Seawater
http://www.copper.org/applications/marine/seawater/seawater_corrosion.html#pump
S.
http://www.corrosionist.com
joeswoes (Materials)
21 Jan 08 12:33
GRP pumps may be less money and impervious to the brackish water
TheBard (Marine/Ocean)
30 Jan 08 12:01
In my humble opinion the best materials for pump manufacture, for centrifugal pumps, pumping sea water are as follows:-
Pump casings..................Ni-Al bronze
Impeller, shaft, shaft sleeves (if fitted), and wear rings are preferably one of the super alloys like monel.
Having worked with pumps manufactureed with these materials, I woulg highly recommend them. Almost trouble free for many years, providing the pumps are started up and shut down correctly. Even then the major maintenance is replacing wear rings if correct running procedures are not adhered to.
Close Box
Join Eng-Tips® Today!
Join Us             Close
