Save As Pdf line weight
Hello All,
I am using SW2005 and when I save my drawings as pdfs the title block line weights are very thick. I changed them to thin with no luck. It prints from SW fine. Also, when I print as pdf it does not give me the pdf extension but .prn. any ideas?
I have created the title block as a block in my drawing template. Don't know if this affects it.
Thanks.
Thanks.
RE: Save As Pdf line weight
Are doing a Save as... and selecting Adobe Portable Document Format (*.pdf) as the Save as type? ... or are you printing to a PDF printer?
PDF995 from http://www.pdf995.com/ and CutePDF Writer from http://www.cutepdf.com/ are good.
