Greek characters in Visual C++ strings
Visual C++/Windows character questsion:  Is there any easy way to imbed some Greek characters (particularly, theta and phi) into a C++ character string for use in the SetDlgItemText command?  I use to be able to print them using ASCII decimal codes 233 and 237 on older DOS C compilers (Borland) but now if I use the same codes I'm getting different characters.  I think I'm getting a new ANSI international character set instead of the old ASCII set back.  Help?
