search Nx 502.2 Replace Face
Where is the replace face option simplify surface in Nx 5.022?
thx in ad
thx in ad
RE: search Nx 502.2 Replace Face
Make sure your Roles are set to Advanced with full menus.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
are you sure? In Nx501 but not in Nx502....
roles are ok
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Justin Ackley
Designer
replace face is a powerful option if you want to edit constructions with no parameters or I've you get a foreign to complex design result ... you can work like ... what you see is what you get... with no care about parameters. What was your problem with the replace face.
Back to the question... where is the option simplify surface?
thx in ad
uwe from germany
http://www
The Google site search works fine.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
that thread related to simplify body...
nothing to simplify surface option in the old replace face feature.
Here you go:
Subject: [PR-01628140] Simplify surface option no more present in replace face dialog
Description of Problem:
PR Number - 1628140
Priority - 1
Fast-Track - YES (Regression)
PR Matrix - 1c
OF Confirmation -
Problem Description: The "simplify surface" option is no more present in replace face dialog.
NOTE:
Is there a way to have it back?
Problem verified on the following Platform and Version(s):
WNTI 5.1 - NX5.0.2.2.
No other platforms tested.
Problem is part specific: No
Problem is platform specific: unknown
Dir Path: No file needed to duplicate issue.
To duplicate problem: Open any part and go to the Modeling application and do the following: insert - direct modeling - replace face.
Notice that te "simplify surface" option is missing.
Traceback from the syslog file
No errors in log file
***** <<<<< This PR has been closed. The resolution was: >>>>> *****
The problem where "Simplify surface option no more present in replace face dialog" is designed as intended.It is hidden by default, it could be shown setting by an environment variables:
For external customer: My computer->property->Advanced->Environment Variables -> new: variable name : UGII_Simplify_Surface variable value: 1
when using UDU to run NX: set UGII_Simplify_Surface=1
PR Number : 1628140
Date Opened: 15-nov-2007
Status : D
Priority : 1
Family : NX
Application: DESIGN
Category : SOFTWARE
Release : V5.0.2
Platform : INTEL
OS : WINDOW
OS Version : XP32_SP2
Terminal : OTHER
Platform specific: Undetermined
-- End of document --
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
great Information
uwe
