CaCO3 Scaling in Wells
Any ideas why I now have screens, columns and shafts scaling in a raw water supply well? When the initial water testing was done less than five years ago, none of the parameters were out of the ordinary. Is it possible for groundwater chemistry to change that quickly? These are 400-600ft wells with water age (according to the experts) in the 10k yr range. Pumping rates have not been excessive. If the water composition hasnt changed significantly, what are some things that can cause CaCO3 to start precipitating? Stray currents? Mixing with treated potable water? (the pump/shaft is water lubed from a potable source since there was not enough pressure topside from the raw water discharge, but it is not a large amount). Testing on the exact composition of the precipitate (initial determination is a carbonate complex, predominately CaCO3 with some iron and MgCO3) is being conducted now.
Any thoughts would be appreciated.
RE: CaCO3 Scaling in Wells
Thanks for the input. Keep it coming
Thanks again
One would think that if the well screen was fouled, you may be releasing the pressure across the screen.
