Rotation of part in assembly
I am attempting to simply rotate a part in an assembly.
Can I do this without using the compass? If not, how would I use the compass to rotate the part?
Thanks in advance.
Thanks in advance.
RE: Rotation of part in assembly
Or stat Catia help and there Mechanical design / Assembly design...
Find icon panel named Moving components and use it's tools.
Or drag the compass (using the center of compass) onto part's surface and simpy rotate the compass using the edges of the compass planes.
-Assembly designer -> manipulation
-DMU navigator -> Translate & Rotate
And some more, but the easiest way is to use the compass, either you drop it on the part and drag the edges for rotation or translation or you double click on the compass after placing it on the part to get the window for more accurate change.
See also FAQ - Some CATIA HOTKEYs description http://www.eng-tips.com/faqs.cfm?fid=1319
Fernando
Here is a brief tutorial that I created using IgniteCAST.com that should answer your question.
http://ww
Cheers,
catiatrain
