whips nd chains mmmm lol
Just being naughty lol
Seriously tho my question is not exactly solidworks related but I do have a question about chains and gears.
sprocket 1 is 200mm dia
sprocket 2 is 100 dia
First example distance between sprocket centers is 1000mm
second example same sprockets but distance is 500mm
which is easiest to turn???
The reason I ask is a person I work with said that if you shorten the length of chain between sprockets it gets harder to turn (think pushbike)But i dont get it ???
Having modeled up a simple gear box with belts a while back and using gear mates what he said doesn't ring right ???
The machine that we were trying to fix today has a lot of sprockets and chains and we think we may have to do some mods on it cool
Thanks gurus
Thanks gurus
RE: whips nd chains mmmm lol
http://chain-guide.com/
SW 2008 SP 1.0
Dell Inc. Precision WorkStation 670
2048 Megabytes Installed Memory
NVIDIA Quadro FX 1400
Windows XP PRO SP 2
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
