Need asistance from the older prop days people
Heres the deal, Full QEC from a KC-97 on the big QEC stand.
The guy says he has haulled it on a flatbed gooseneck trailer rated at 14k lbs, behind a 3/4 ton. Not sure of trailer specifics, as far as tire size bed height etc. I guess what I need is a vertical CG location of the complete unit, then of course the trailer it is chained to facters in. I would like to know the max side tip angle before it falls over. If anyone has experience with this please give some suggestions. Thanks
RE: Need asistance from the older prop days people
If you don't mind me asking, why are you worried about it "tipping over".
I don't have any tech orders or data on it.
Maybe someone at Davis Monthan (sp) AFB in Tucson Az would have data.
fwd/aft cg position would be approximately 1/4 chord (1/4 of the distance from the leading edge of the wing to the trailing edge.
i'm not sure about the empty weight, 14000 lbs sounds pretty low to me
The poster is asking about the CG of the Quick Engine Change stand. (QEC)
B.E.
