Changing many spot elevations (leaders) at once by a numeric value
Hi all,
Often after grading a site using leaders, we have to raise or lower the site. Is there a way or a lisp routine that will aid in raising or lowering a group of leaders by a measurement? Such as, raise (or lower) every spot elevation by 0.8'?
Thanks in advance
:P
RE: Changing many spot elevations (leaders) at once by a numeric value
I have a routine that would do this for regular text entities, but I assume your leader text is 'mtext', so it would have to be modified.  If you don't find anything you could email me a sample leader you use and I'll see if I can adapt this routine.  cab@eeiteam.com
Carl
