304SS Bonding Products
We are having an issue with a baghouse where catalyst leaks through the joining seams. The first idea was to seal weld the seams, but this would take up way to much time and money. Im looking for a DEPENDABLE product that we could poor in these seams to end our problem. The baghouse gets to a temperature of about 400*F. The tubesheet to be sealed is made out of 304ss. If anyone has any suggestions it would be greatly appreciated!! Thank you!
RE: 304SS Bonding Products
http://www.welding-advisers.com/
Welding is your only real solution.
Maybe you shouyld look at welding the major areas and then using epoxy to seal the rest.
Plymouth Tube
