Stiffness/Damping coefficients at nonsynchronous rotational speed
Hy,
the calculated stiffness- and damping values for plain cylindrical journal bearings are valid only for forces with rotational speed. How do they change with much higher frequencies (10x rotational speed) ?
Thanks for your comments
Frank
Frank
RE: Stiffness/Damping coefficients at nonsynchronous rotational speed
Bill
Typically above a certain speed the curves flatten out and the KXX and KXY coefficients stay the same...
"Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?" Oddball, "Kelly's Heros" 1970
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
