Removal of DO from Brine Solution
I'm reviewing options for removing dissolved oxygen from a brine waste stream (25% solids) to prevent possible downstream corrossion or bio issues.
What would be the best chemical for this application? I've seen reference to sulphide.
Any help on a balance equation for commention DO removal would be appreciated.
RE: Removal of DO from Brine Solution
You are referencing a chemical called sodium sulfite that is commonly used as a oxygen scavenger in boilers. That chemical is only used after a vacuum deaerator is used to remove the bulk of the oxygen. It would probably be expensive except for small quantity usage.
http://www.arkema-inc.com/literature/pdf/346.pdf
http://w
If you are concerned regarding corrosion, the cheapest approach is generally an acid such as sulfuric to raise the pH. For bio issues, the common treatment for control is chlorination.
