How to create Macro
How to create Macro
How to create Macro
Hi
How to create macro for taking cross-section and dumping in layer.
After importing part in UG, it should take lathe cross section and dump the cross section in particular layer.
RE: How to create Macro
Why are you creating a 'lathe' cross-section?  Our NC Turning module allows for the automatice creation of an associative cross-section to be used to provide the profile used to create the toolpaths.  When done as part of a Master Model NC model, there is no need to segregate the profile to a different layer since that profile will only exist in the NC model and not the Part model.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
What version of NX are you using ?
Like John since NX4 you can use the solid model to "Spin" a lathe profile.  Make sure you have a Workpiece defined, (this is the same "workpiece" object that is in milling) and pick the Solid model as the part geometry.
When you edit the turn_workpiece the boundary should already be there. See the attached image.
John Joyce
Tata Technologies iKS
1675 Larimer St.
Denver, CO
www.myigetit.com
