Connection for C6 and C4
We had a job where the customer changed from grating to floor plate. We had to go back and add beams for the floor plate. We used C6. In AISC 13th edition all double angle connections are two rows and all single plate connections are two bolts. Can we go to single row on the double angle connection and a single bolt for the single plate connections. The end reactions are less than one kip.
RE: Connection for C6 and C4
