Hydraulic Fluid Replacement frequency
How do you determine how often to change hydraulic fluid?
We have a custom-made hydraulic test machine that is fairly low pressure (2000 psi max), and it's been 10 years since the fluid was changed. We use it almost daily, but probably 1-2 hours of operating time a day.
Will the fluid break down, or will filtering for contaminants be enough? It's a pretty well sealed system, so the seals and other contacting surfaces are about the only thing that will contaminate it.
Thanks!
Thanks!
RE: Hydraulic Fluid Replacement frequency
It is time to replace the fluid.
You could have the fluid chemistry checked. But your are time ahead to just change the fluid.
Ted
Johnny Pellin
The system doesn't get too hot, as it's usually running at a lower pressure than I mentioned (2000 psi max, 800 psi norm).
And we have right around 50 gallons, so it's probably just one of those borderline decisions. Actually, with 2 machines we'll be up to 100, so it may be worth checking the cost for testing if we can find someone close.
