wood floor joists on slab on ground
Has anyone seen this type of construction. House in Florida, built in 1986, has 2x8 floor joists siting on slab on ground.
Any reason for this? Is this typical in this area? Does this type of framing have a name?
RE: wood floor joists on slab on ground
Also you can run services under the floor boards
Don Phillips
http://worthingtonengineering.com
Mike McCann
McCann Engineering
