Creating Surface Finish and GTOL's in Drawing Mode
I have a model where I created some surface finish and geometric tolerances in the drawing mode. When I went back to the model, the geometric tolerances and the surface finishes were part of the model. I don't want them to be seen in the model and I can't figure out a way to "hide" them in the model mode. Any ideas on how I can do this or should these only be created in the model mode?
Thanks for your help.
RE: Creating Surface Finish and GTOL's in Drawing Mode
Create a layer & set the rule options to be Independant & Associative
Edit the rules to add Geometric Tolerance & Surface Finish to the layer.
Hide the layer
Ensure that the config option in the drawing dtl file - ignore_model_layer_status is set to yes
