Thread Orientation dimensioning
I am to draft drawings for parts which has a male and female threads. These parts are required to be orientated using the threads, I am not aware of dimesioning threads with a tolerance to the orientation. The tolerance however is + or - 4.5 degree and both the threads are to start from 12 o clock i.e 0 degree. Are you aware of any dimensioning practise for this purpose. Need more info please let me know.
Mechotron
Mechotron
RE: Thread Orientation dimensioning
If this is not possible, locate your datums, and put a feature control frame on your hole note as you would on a regular, drilled hole. Locate the position of your threaded hole within Øx of datums A, B, etc.
This is how I would do it, unless I'm completely missing the situation.
Good luck!
V
Mechanical Engineer
"When I am working on a problem, I do not think of beauty, but when I've finished, if the solution is not beautiful, I know it is wrong."
- R. Buckminster Fuller
I don't know of any way to do this other than an explanatory note.
I could also be completely missing the situation.
Hard to tell how to apply in your case without more detail of the part shapes involved.
Remember...![[idea] idea](https://www.tipmaster.com/images/idea.gif)
"If you don't use your head,
your going to have to use your feet."
V
Mechanical Engineer
Chris
SolidWorks 08 0.0/PDMWorks 08
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
Using the thread in this manner and applying a start position is practically not practical.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
I persume that a text is possibly the best way. can i ask you what is a GD&T.
Mechotron
mechotron
Chris
AutoCAD 06
ctopher's blog
