SQL JOIN several tables help required
Hi guys,
I've so far had no luck getting help or solving this on my own! I have four tables which I need to join together. They are
SO - I need ALL the records from the METRICS_CUSTOM_REPORT table based on the processID, then I need to look up the name from METRICS table. I then need ANY records in the METRICS_CALCULATED_ANSWERS and METRICANSWERS table (IF they exists). There will ALWAYS be a record in METRICS which matches the ID number from METRICS_CUSTOM_REPORT table.
Here's what I have so far - but I cannot get in the metricanswers table. What am I doing wrong?
Thanks for any help.
CODE
METRICS
metricID processID name
R3451 1.01 Metric1
R7764 1.01 Metric2
R0443 1.01 metric3
metricID processID orgID
R3451 1.01 mydemo
R7764 1.01 mydemo
metricID processID answer year
R3451 1.01 12.34 2007
R7764 1.01 114.55 2007
METRICANSWERS
metricID orgID target year
R3451 mydemo 13.00 2007
R3451 1.01 Metric1
R7764 1.01 Metric2
R0443 1.01 metric3
R3451 1.01 mydemo
R7764 1.01 mydemo
METRICANSWERS
CODE
SELECT
m.*,
c.*,
mca.*
FROM metrics_custom_report c
LEFT JOIN metrics m ON c.metricID = m.metricID
LEFT JOIN metric_calculated_answers mca ON mca.metricID = c.metricID
WHERE c.orgID='$orgID' AND
c.processID='$processID' AND
m.processID='$processID' AND
mca.processID='$processID' AND mca.orgID='$orgID' AND mca.year='$year'
GROUP BY m.metricID
m.*,
c.*,
mca.*
GROUP BY m.metricID
RE: SQL JOIN several tables help required
SELECT C.*, M.name
FROM metrics_custom_report C, metrics M
LEFT JOIN metric_calculated_answers A ON A.processID = C.processID
LEFT JOIN metricanswers W ON W.metricid = C.metricid
WHERE C.metricid = M.metricid
GROUP BY C.metricid
ORDER BY C.metricid
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
