CENTER GRAPH issue
CENTER GRAPH issue
I work with ENOVIA VPM, if I use CENTER GRAPH option in CATIA when trying to find a part in a tree, CATIA loads some information from VPM and it last long time. I use R16, in R14 CENTER GRAPH worked fine, very quick, now I have to wait long time to find a part in a tree. Can I do something to improve it or it is some kind of bug in R16?
Thanks.
Thanks.
RE: CENTER GRAPH issue
As far as I know, switching from one release to another it takes a little bit time due to the fact that CATIA needs to do a reconciliation between parts made in different releases.
If you don't have all the parts already saved in r16, maybe this is the reason...(and thats why some companies skip some releases...).
Maybe I'm wrong, if it's so, please correct me.
Fernando
