What is the ANSI Standard # for Gage Calibration?
I am new in calibration. A customer asked me what ANSI standard do you use to calibrate the caliper, micrometer, depth gage, etc., I can't find the answer from the internet. What I do is according to the supplier’s spec. or catalog.
Is anyone can help me? Tell me the ANSI Spec. # for different gages or where I can find it.
Thanks a lot.
RE: What is the ANSI Standard # for Gage Calibration?
allenchu,
Here is a link to ANSI within which you can search for standards.  There are numerous possibilities when it comes to Gage Calibration/Traceability/Control systems.
http://www.ansi.org/
The brief search I did using Gage Calibration turned up ANSI/ASME B89.1.2M-1991 on the calibration of Gage Blocks.
A search using just the term Calibration brought up over 1000 hits which you could sort through.  Some examples.
A-A-53420A
CALIBRATION AND VERIFICATION SYSTEM
ISO 10012:2003
Measurement management systems - Requirements for measurement processes and measuring equipment
You could also look at ISO 17025.
See PFI ES-32
If applicable see the following:
ASME B89.1.6 Measurement of Plain Internal Diameters for Use as Master Rings and Ring Gages
ASME E 74 Standard Practice of Calibration of Force-Measuring Instruments for Verifying the Force Indication of Testing Machines
go to the ANSI Standard site
