color sensing tranducer.
Hi there,
Would appreciate anyone out who can recommend a low cost
color sensing transducer for checking the wrong color orientation in wire harness asssembly. I know Keyence do have some types (mainly fibre optic type) , but they are quite expensive. Can we use any other sensors?
RE: color sensing tranducer.
Good luck,
stan
Thank you very much for your help. I was able to get some
technical info on from the manufacturer. Yes I am putting the interfacing stuff and hope to see the stuff kicking well
and fine.
Joy to you.
Awesome, good luck and I hope it all works out!
Stan
http://www.ab.com/sensors/sensorstoday/nov99/nov99_tech_talk/
http://www.taosinc.com/pdf/SensorsExpo2001.doc
etc. for more info.
Joy to you.
MM
