VB UserForm with Icon in TitleBar
If you want to add an icon in your VBA UserForm ; the same one than your button in toolbar for example.
You can add this code in UserForm's code.
Add this code at the begining of the code
CODE
' first we declare some external used functions
Private Declare Function FindWindow Lib "user32" Alias _
"FindWindowA"  (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
Private Declare Function SendMessageA Lib "user32" _
      (ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Integer, _
      ByVal lParam As Long) As Long
Private Declare Function ExtractIconA Lib "shell32.dll" _
      (ByVal hInst As Long, ByVal lpszExeFileName As String, ByVal nIconIndex As Long) As Long
Then we can add the Initialize sub or add this text in the existing one.
CODE
' Initialise UserForm with icon
Private Sub UserForm_Initialize()
    Dim uFile As String
    Dim x As Long
     'Full path of the picture (UNC works too)
    uFile = "C:\MyPicture.bmp"
    ' Check if the picture file really exists, if not -> termine the sub
    ' Be careful if you have code behind this (maybe goto)
    x = Len(Dir(uFile ))
    If x = 0 Then Exit Sub
    'Extract icon from picture file, and put it in the TitleBar
    x = ExtractIconA(0, uFile , 0)
    SendMessageA FindWindow(vbNullString, Me.Caption), &H80, False, x
End Sub
The result :
I hope this tip will be useful !
SW2007 SP5
Worksatation HP wx4300 2GB
NVidia Quadro FX 3450
RE: VB UserForm with Icon in TitleBar
Florent,
I will have to give it a try.
Regg
fcsuper ;
sorry for my bad English but, I don't understand what you mean by "Autoloading".
The icon is loaded dynamicly. Is that what you wanted to say ?
In my case, I use the same picture for the button toolbar and the icon in title bar.
For your second question, I really don't understand ...
And for the last one, did you want to add a toolbar in your VB form or in SolidWorks windows ?
SW2007 SP5
The main thing is to succeed in understanding ourselves.
2thumbsup
SW2007 SP5
