STEEL PLATE DEFLECTION....
HELLO, I'M NEW HERE... I HAVE A QUESTION I WAS HOPING SOMONE COULD AIDE ME WITH... WHAT I NEED IS A FORMULA PROCEDURE FOR THE FOLLOWING SENARIO... I HAVE 4 STEEL PLATES, "THKNESS AND TYPE VARIES FOR THE PLATES" THAT IS WELDED TOGETHER TO MAKE A STEEL RECTANGULAR BOX BASICALLY... IN THIS BOX WILL BE A FLUID AT ANY GIVEN PSI... WHAT I WANTED TO KNOW IS HOW TO CALCUTED MY DEFLECTION AND ALSO AT WHAT POINT I WILL NEED TO ADD SUPPORT OF THAT MATERIAL AT A PSI GIVEN.... ANY HELP WOULD BE GREATLY APPRICIATED...
RE: STEEL PLATE DEFLECTION....
http://www.xcalcs.com/cgi-bin/tutti/x2calcs.cgi
How catastrophic would a failure of your box be? Will there be property damage? Personal injury?
If this were a bucket with a couple of liters of water in it, you would not be asking us questions. It was a good idea for you to ask. At some point, most of us have to step back and allow a qualified professional to take over. It sounds like you are there.
JHG
