PGMFI Clear Flood operation?
During Clear Flood operation injectors are turned off when a high a TP signal is detected by the pcm in ignition on engine off state. My question is how long are the injectors turned off for? or are they off until a threshold of xxx engine RPM is reached?
I don't feel like taking the rail off to find out the answer :)
RE: PGMFI Clear Flood operation?
Usually until the throttle is released.  If the engine drys out enough to start combusting the first thing people do is take their foot off the throttle.
Vernon
