Assembly rotary simulation Error??
I am trying to create a cylinder lock that turns a shackle to lock/unlock a door. (If youre not familiar with cylinder locks, it is a movable inner cylinder co-centric with a stationary outer cylinder.) And I have the part files complete and the assembly together (with a key inserted), but when I try to simulate a rotary motion for the inner cylinder, it pops up an error about there being collisions at the start of the motion EVEN THOUGH I checked for interferences and there were none. Furthermore, I found that I cant use the Move tool to even make a manual rotary motion of the inner cylinder. Any ideas as to why this isnt working??
Thanks a ton
Thanks a ton
RE: Assembly rotary simulation Error??
You should be able to just grab the key and rotate it without using the Move or simulation/animation tool.
Dan
www.eltronresearch.com
