spare parts for GEreg model GR voltage regulator
Hi all
Does anyone know where spare parts could be found for repairing or replacing a GE model 3S7950GR400 static voltage regulator? The unit we have has a failed main control card. We think the SCR bridge is still OK, but would replace the entire unit if a spare could be found.
Any information regarding sources for old GE AVRs or replacement parts would be helpful. The AVR is on an old synchronous generator (vintage 1920's) with a large DC rotary exciter.
Thanks for any leads anyone can give.
DM
RE: spare parts for GEreg model GR voltage regulator
GE manuafactures all exiters in Salem VA.  Please try your luck.
Vintage system from 1920??  You need more luck than information!!
I believe this is the guy I cross paths with years ago.  If so He is very knowledgable and should be able to locate parts or be able to make the repairs
http://www.basler.com/html/sesturnkey.htm
If he's not the one, he still might be able to help
