why silicone temperature higher that die temperature?
For high power LED, why the temperature of silicone can reach around 200 degree C although the die temperature only around 100++ degree C?
where can i find related journal regrading to the Q?
RE: why silicone temperature higher that die temperature?
If we use FEA method to simulate or analyze LED, i will found that the temperature of silicone is lower than die tempperature. however in real life, the silicone temperature is much higher than die temperature as i mentioned before this.
In order to solve this problem,we must know what is happen so that we can set all those initial condition and so on to do analysis.Am i right?
And to start, what software are you using?
I would encourage you to find a consultant in your area and ask him/her to help you through a problem or two. Or, you may be able to contact your software representative and see if they can provide a tutorial or some resources for material information.
