Vessel and Head Weights
I have been using a formula for finding the weight of a vessel, Wt.(lbs)=A(40.8)t; where A=surface area (Sq. Ft.)
t=thickness of shell in inches
40.8= density of steel (lbs/in/sq.ft.)
I have seen a reference to using 41.15 instead of 40.8
Can anyone help me refind the reference
RE: Vessel and Head Weights
I have never seen the 41.15psf/in used.
Possiblilties for the larger number:
1. Slightly higher wt is used for ss if you are using warehouse billing wts for ss.
2. The user has included extra for mill overtolerance.
3. If for formed heads, manufacturer may include factor based upon experience.
You are accurate if you calculate weights of components based upon actual wts & the 40.8psf/in for plates + a nominal allowance (say 5%-10%) to account for mill/part overtolerance, welds, paint, + misc small items for which it is a waste of time to add (i.e., small couplings, bolts, gaskets, etc.)
prex
motori@xcalcsREMOVE.com
http://www.xcalcs.com
Online tools for structural design
Weight CS: Length x width x thick x 0.2833
Weight SS: length x width x thick x 0.2857
(Above in US units)
