GD&T of magnets
GD&T of magnets
GD&T of magnets
Can anyone tell me the proper way to GD&T magnets with their orientation, polarization, etc., or where I might be able to track down such information?  Thanks!!
-Fred
RE: GD&T of magnets
Just do GD&T on the physical part. There isn't GD&T for orientation and polarization. You may need a note for grain direction, depending on the material.
Chris
SolidWorks 08 0.0/PDMWorks 08
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
RE: GD&T of magnets
Fred,
As Chris mentioned, I do not believe there is symbology for magnetism in mechanical drafting, but there may be some in electrical drafting.  Don't a bried yahoo search, I found this link that may point you in the right direction:
http://www.bnl.gov/magnets/magnet_files/Publications/MDN-609-20.pdf
It's dealing with electro-magnets, but may have some clues to answer your question.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
RE: GD&T of magnets
Here are some notes that I put on my last drawing for a Neodymium magnet.
Magnets Rare-Earth Neodymium-Iron-Boron Magnet
Shape - Disc
Dimension - Diameter 0.250" (6.35mm) x Thickness 0.100" (2.54mm)
Material - Sintered NdFeB
Magnetization - Magnetized
Magnetization Direction - Axially Magnetized
Plating – Nickel
Temperature Range (Deg C) - 0 to 80
Dimensional Tolerance - (+/-0.005")
Grade N30
Pull Force - 2.14lb/971g
Heckler   americanflag
Sr. Mechanical Engineer
SWx 2007 SP 4.0 & Pro/E 2001
      o
  _`\(,_
(_)/ (_)
This post contains no political overtones or undertones for that matter and in no way represents the poster's political agenda.
