Document Routine Needed
I am trying to automate the process of converting thousands of MDT files to Solidworks.  We have already broken down our product lines into part types and have begun the process of creating part files and configurations.  What I need now is an automated way to output drawing files.  I have a template drawing set up with the dimension scheme that I like.  I just need to be able to cycle through the configurations and do a save copy as with the configuration name as the name of the file.
The only part of this routine that I am having problems with is the cycling through the configurations.  I cannot seem to grab the available configurations from the view.  Am I doing something wrong?  Do I need to load the part/assembly file to grab the configurations?
Any Ideas?
My Sample Code:
Option Explicit
Dim swApp As Object
Dim Drawing As SldWorks.DrawingDoc
Sub main()
    Dim View As SldWorks.View
    Dim Model As String
    Dim Configuration As String
    Set swApp = CreateObject("SldWorks.Application")
    Set Drawing = swApp.ActiveDoc
    Set View = Drawing.IGetFirstView()
    Set View = View.GetNextView
    Model = View.GetReferencedModelName
    Configuration = View.ReferencedConfiguration
End Sub
RE: Document Routine Needed
First, you should define Drawing As Object in your VBA code. The method you have is for early binding, which is not needed.
I will look into the rest of it and get back to you.
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
Here you go. This will loop through all of the drawing views on the active drawing. NOTE: It does not test to make sure the active document is a drawing. I think the main problem with your code was your use of IGetFirstView instead of GetFirstView.
Option Explicit
Dim swApp As Object
Dim swDwg As Object
Dim swView As Object
Sub main()
    Dim sViewName As String
    Dim sModelName As String
    Dim sConfigName As String
    Dim sMsg As String
    Set swDwg = swApp.ActiveDoc
    Set swView = swDwg.GetFirstView()   'Drawing Template
    sMsg = "VIEW NAME : MODEL NAME : COFIGURATION NAME" & vbCrLf
    On Error Resume Next
    Set swView = swView.GetNextView
    Do While Not swView Is Nothing
        sViewName = swView.Name
        sModelName = swView.GetReferencedModelName
        sConfigName = swView.ReferencedConfiguration
        'Build String
        sMsg = sMsg & sViewName & " : " & _
                      sModelName & " : " & _
                      sConfigName & vbCrLf
        If Err.Number <> 0 Then
            Err.Clear
            Exit Do
        End If
    Loop
    MsgBox sMsg
    Set swView = Nothing
    Set swDwg = Nothing
    Set swApp = Nothing
End Sub
Hope this helps...
That's great!  Thanks for the help.
Will I need to open the part or assembly file sModelName in order to get a list of available configurations?  I think that is the only to do it.
I am not sure. You may be able to reference the part directly from the drawing document. You just need a handle to the part.
For a list of available configurations:
Dim swApp As Object
Dim Part As Object
Dim ConfigNames As Variant
Dim iConfigs As Long
Dim i As Long
Set swApp = GetObject(, "SldWorks.Application")
Set Part = swApp.ActiveDoc
'Get a list of Configurations
iConfigs = Part.GetConfigurationCount
ConfigNames = Part.GetConfigurationNames
For i = 0 To (iConfigs - 1)
    MsgBox ConfigNames(i)
Next
Thanks again for your help, but this does not appear to work in the .SLDDRW file.  I will try opening the part file to see if that works.
